1986 OMC 120 Timing marks
OLs70
Hi,
Due to changed condenser, points and plugs I need to adjust the timing. I can find the timing mark on the pulley, but on the engine block is a plate with several marks: Which one should match with the mark on the pulley at idling speed?
What should the idling speed be?
Which mark should match at e.g. 3000 rpm?
Thanks!
Re: 1986 OMC 120 Timing marks
Ayuh,.... Welcome Aboard,...
If the Tab isn't rusted too badly, they usually clean up enough to read...
There's also a few pictures floating around the forums here that show the Timing Tabs on these motors,...
A Search should turn up a few....
Idle speed should be 650/ 750rpms.....
I think those motors like running at about 4?BTC,.. maye 6?BTC....
That's at Idle.....
No reason at All to rev a motor to 3000rpms to set the Timing....
OLs70
Hi again,
Yes, I managed to find a picture so now i know how it should look. Let's see if something will show up under the rust :)
If not, I'll find the TDC and assume 4? per edge.
Thanks for the tip!
That's at Idle.....
