Replacing vinyl
danielclubs
Hi everyone,
I have an '87 Starcraft runabout and would like to start replacing the vinyl interior. I am thinking of beginning with the side panels along the length of back half of the boat and then working on the "simple" seat backs. I plan on purchasing two replacement reclining seats for the driver and passenger and having a local sewing business replace the vinyl on the few remaining seats at the rear and bow of the boat. In other words, I'm trying to do this cost-effectively and yet look nice in the process.
One question, the long side panels have the typical "button" that covers a screw behind it has the foam insulation. Does the panel plywood typically come off relatively easily? I haven't tried yet as I'm a bit nervous about the process.
Thanks in advanced for any help! Dan
Re: Replacing vinyl
usually, unless it is a bolt and nut, but usually are screws.
xxxflhrci
Re: Replacing vinyl
Behind the button, you will find a hole. If you dig around, you will find a Phillips head screw head.
danielclubs
Re: Replacing vinyl
I haven't tried to pop off the button yet. Would it be a "snap" button? I'm just concerned about putting it back on when I'm done.
Thanks again, this forum is really fantastic!
xxxflhrci
Re: Replacing vinyl
On mine, you can just turn the buttons half a turn and see the hole.....If you are recovering it, what's it matter if you tear off the buttons or cut the vinyl for that matter?:D
Chinewalker
Re: Replacing vinyl
We did away with the buttons on ours - just one more thing to catch grunge and dog fur. When rebuilding them, I pre-drilled the holes for the mounting bolts and epoxied them in place. All of mine were nutted from behind, inside the side wells, so it was just a matter of tightening them up from behind. Makes for a neater finish without all the buttons, plus fewer areas for water to get inside......
- Scott
