Re: how do I hook up a tachometer?
You need a standard 2 cycle tach with that engine, and even then, some brands will work, and some won't. I'm not sure, so ask over at The Chrysler Crew.
If you have magneto ignition, two brown wires will come out from under the flywheel. These are the kill circuit. They are also tach signal. You need to use one of them and set the tach to one pulse per revolution. If you have coil ignition, use one of the white wires to one coil as a source of signal.
