40hp motor quit while under way
I have a 2002 40 hp elpto on a 18 ft pontoon boat. While running @ 4500 rpm the motor quit. Fuel system was delivering, spark plug was wet. I changed plugs on the water, no start, still wet plug. 20A fuse on top of flywheel cover is OK. All help is appreciated in diagnosis.
JB
Re: 40hp motor quit while under way
Engine FAQs, "Outboard won't start". Let us know what you find.
kskomro
Pull your spark plugs one at a time, ground them to motor, and crank motor. See if you have spark.
kskomro
I'm sure you've checked your kill switch right. Do you have spark on any of the plugs ?
I did check the kill switch. No spark on either of the two cylinders. Someone mentioned a dropped magnet on the flywheel, but I don't have a flywheel puller to check. Also Merc service manual mentions triger, ignition module, or RPM limiter. Has anyone had a somular problem. I would like to attack the most likely rather than throw $$ into parts not needed.
Thanks for all sugestions
