Do boats lose top end speed in the hotter months
Robertpel9
I have a 1995 Chris Craft Concept 18 with a Volvo Penta 4.3GS (205Hp).
When i first got the boat in April it would run ~51 on the speedo and a GPS confirmed 48.9
This past 5-6 weeks with the same load with temps consistently in the low to mid 90's I am maxing out at about 46 on the speedo (Have not GPS'ed it) but i have lost 5 mph on the speedo.
Everything is in good running order, looks and sounds great, fluids are good to go
Is this like a high performance car where the engine just likes colder temps or may I have an issue here that is deeper and should be looked into? The air is about 15-20 degrees warmer and the lake i live on (Lake Norman) now has a surface water temp of 85-86 degrees vs about 70 degrees when i got the boat.
Operating temps on the coolant temp gauge are exactly the same all year thus far
gcboat
Re: Do boats lose top end speed in the hotter months
Yes they do. It all relates to the temp of the air / fuel mixture. Has nothing to do with the temp of the water you are on - but they are both relevant.
jeeperman
All engines theoretically produce more power with cold air intake.
And you might have some growth on the hull creating drag.
marine4003
Around here i lose 5-10 MPH in the dog days of summer due to trying to cut thru 90% humitity.....
Robertpel9
OK good, thanks for the replies, i feel better now.
I jusp in every weekend with a brush and wipe down the outdrive and the entire hull to get off any growth before it gets a chance to stick and i am about 90% successful so i do not think i have extra drag but today for instance it is 97 and humid so i am slow
oops!
i will abosluetly gaurentee you that unless you lift your anchor, or untie the dock line your are going to go slower reguardless of outside temp....:D :D
all funnin aside,
in a hot day, air is expanded, not as much in the cylinders. less heat generated, less bang in the holes.
on a hot day an airplane will require longer runways than normal beacause the air is "thinner".
take the boat out on a cool morning and see what happens.
just make sure to lift that anchor ! :D
cheers
oops
