SS MAYFLOAT
Thread starter- Joined
- May 17, 2001
- 6,372
Last weekend a friend of mine finally got his boat docked. He did his own A/C install. To install it, he had to cut the freon lines and rerouted them to be able to have the necessary space for the stuff to fit. I checked the system out and it looks okay, but he has problems. I know why, but he refuses to believe me.
When he got his lines all soldered in, he installed line tap valves (which I never use due to their ability to leak). He never evacuated the system. He was told by another pro that it was not necessary. Huh? I never heard that one. He then says that it works, but when it starts getting hot out, the amp draw goes sky high and trips his breaker. I told him it was because of all the non-condensables that is in the system and that it needs evacuated. Then he changes his story that his pro friend did the work.
I have never heard that you can successfully charge a system without pulling it into a vacuum. Has anyone else heard this? I have been trained that for a system to successfully be charged, a vacuum must be done. This just goes against all my training...........
I'll get him to log on later to see the responses......Thanks..........SS
