Re: '89 Evinrude 48 spl Won't stay running.
Ancient Mariner,
I've had it awhile, but never had it running. First the power pack was bad and the coil. Then it was wired backwards and backfired. I took off the carbs and cleaned them best I could and installed kits in each one. Like I said, no matter what I seemed to do it just fires up then immediately dies. Compression on #1 seemed, initially, lower than 2, but is okay now. I've got the fuel pump off to rebuild it. After I try to start it I can restart it and again it will fire up strong and then die. After a few times, of course, I have to reprime the carbs. It won't run long enough to be able to bump the ignition key to keep it running. I even drained the gas tank and put fresh gas in it. If you have any other questions, let me know. Thank you for your time and help.
George3405
