1984 50HP Mercury
mr2jl
I rebuilt both carbs and fuel pumps. Motor runs good but when I hold it wide open for a period of time I lose power. When it's losing power I can squeeze the ball and then the power comes back. It is starving for fuel. Any ideas what could be wrong? Thanks.
mr2jl
Re: 1984 50HP Mercury
Thanks, already rebuilt both fuel pumps and still has the same problem.
emckelvy
You may have a bad check valve in the fuel bulb or other problems in your fuel system. Mercury has an upgraded primer bulb that's supposed to cure problems with sticking/restrictive check valves. You might try renewing the primer bulb and fuel lines and checking your tank for proper venting.
If you have a portable tank and hose assy that's known to be in good working order you might try that to see if the problem continues. If it does, there's still something going on with your motor's fuel system.
In that case, I'd pull the fuel pumps and check for debris lodged in the check valves or other obvious problems. Also it's not unusual for deteriorating fuel lines to cause a restriction so that's something else to look for.
HTH & let us know what you find.........ed
rainbro
Any luck,My 83 50'hp does the same thing I can drive 5 min full throttle and power dies.when it cools it seems to be ok again.it seems to be running on all 4 cyls also.if you find a solution can you let me know?
