scott killmon
Thread starter- Joined
- May 30, 2008
- 4
Hello all i have recently replaced my 120 mercruier with a 140 after thinking that i threw a rod bearing. Come to find out after putting a load on the 140 the same knock returned with some other surprises. When i hit 2000 on the tach the engine started sliping and increased rpms. My question is i know know that the gimble bearing is what was causing the knock but what futher damage have i caused with the sliping? I read that the engine coupler was rubber spined and i did smell rubber burning. I also had a problem when installing the 140 the engine coupler was bigger than the 120 and was hitting my water intake hose, I adusted this hose a much as possible and from what i can see it is not touching. Im not at a comple loss by replacing the 120 the 140 runs great!! This was my first engine replacement, and will be my first gimble replacementm, any thoughts will help. Thanks agian
