Hi, I've got an 87 Merc 150 Black Max outboard that's just developed a tach issue, basically at an idle the tach reads around 2000 RPMs, and it doesn't change much until it's really wound up - best described as erratic tach. I've read about checking voltage on the grey wire and, correct me if wrong please, but it should be like 3.5vac or so at idle? I'm getting around 13 at idle!!!
(and closer to 20 at what I guess to be around 2000 RPMs).
Does this sound right?
Is this going to be a bad rectifier, or could this possibly be a bad stator?
The way the wires connect to the rectifier it would almost seem like whatever voltage was on the yellow wire from the stator would be translated directly to the grey tach wire....? Or no?
Also, I don't have the factory manual, I've got another brand covering a lot of different years and sizes, and the wiring diagram they give me for this doesn't show exactly what I've got, specifically it seems to be missing the voltage regulator!??
Does anyone have the correct wiring diagram for this....or can anyone just confirm the wiring is correct?
Looking at the rectifier I've got 3 terminals on it, one marked (+) that has 2 red wires on it, one going to the voltage regulator, a second terminal with the grey tach wire and a yellow wire from stator, and a third terminal with a 2nd yellow wire from stator and a yellow wire from voltage regulator.
Thanks for your time guys.
