Suntracker sink wont pump
6 balls
I have a 08 Party Hut with a sink I refilled the water tank and put the hose back in and now no water comes out the faucet. Is there a trick that the pump has to be primed before it will pump????
12vMan
Re: Suntracker sink wont pump
Is it an electric or manual pump? Either way it shouldn't need priming.
If it's electric, can you hear the pump running? You should be able to hear it, and if you can't you'll have to start checking switches, connections and fuses.
Make sure the hoses are all tight and don't have any loose connections that can suck air in, and make sure the pick-up hose is completely immersed in water.
6 balls
thanks for the quick reply the pump runs fine and I put the hose in a glass of water to make sure that it is not taking air and still nothing comes out the faucet all worked fine until it ran out of water
