LKFRK BASSER
Thread starter- Joined
- Jun 30, 2008
- 4
(2007)225 hpdi yamaha has (only) 11psi @4000rpm to wot!This is obviously a newer motor and used to have 20-23psi @ above rpms.Took boat to dealer and they replaced water pump and told me problem was solved.Problem still exists..would like to clean "Poppit"? valve myself but not sure where to find it on motor and proper prodedure.Do have a SeLoc 1997-2003 Yamaha repair manual and have read a few post with same problem:Just a little more info from the experts on location and proper procedure.Also any comments on wether this is the next thing to check or not would help.Also (verified) that water gauge on boat [is]working and accurate.Thank-you! for the help guys!
