Question regarding my 81 7.5hp Chrysler Sea King outboard. I replaced all of the fuel lines on the tank and motor. I put a clear fuel line from the fuel pump to the carb so that I could see the fuel flow. I started the motor today and noticed that there was air in the fuel line from the pump to the carb. It was not there when I initially squeezed the bulb to prime the fuel lines. As the motor ran, more and more air began to fill the line and it has a very small flow of fuel. I had to keep sqeeezing the bulb to maintain fuel pressure in the line and to keep the motor running. Is the fuel pump dying? Like I said earlier, I replaced the fuel lines, so I can't think of how there would be leak allowing air in unless the quick connections from the tank to motor are bad. Any help is appreciated.
