Re: got a problem
Define "Clunk"? If something is banging around in the lower-leg then something is broken and you'll have to take it off to know what it is. If its "ratcheting" as though its not traveling far enough to engage the gear, then it could just be a matter of adjustment.
Put the control Box (CB) in forward about half way, then take the gear linkage off at the side of the motor and see if you can manually put the gear leaver farther towards 'forward'.
Then turn the prop and it should click/ratchet Clock wise, but not CCW. It shouldn't freely spin, but it will click past fairly easy.
Yet to be honest, it sounds like you have something broken in the lower-leg. Probably the prop-shaft, based on what I would call a 'clunk'.
Also, did you adjust the linkage, or not? "No luck" as in it didn't work, or you couldn't do it?
