donmagicjuan
Thread starter- Joined
- Jul 2, 2008
- 11
Hello all. I have an 87-95 Merc 350 (4bbl) direct drive with the center riser style exhaust manifolds. I recently replaced the engine with a reman due to a cracked block (I was unable to winterize the boat last year, but I'll welcome your harrassment for it anyway), and I reused the exhaust manifolds from the original engine. I believe I tested them to be ok, but now I'm second guessing myself and would like to hear your thoughts.
In my mind, the ideal method for testing the manifolds would be a leakdown test by sealing off the water entrance/exits and filling the water side with compressed air. However, I was having trouble coming up with a way to seal off just the water exits. Instead, I hooked up a garden hose to the water inlet hose and ran water through the manifolds for an extended period of time until I was satisfied that nothing was making its way into the exhaust side. I've since installed them on the engine, and everything seems to be ok (new engine has 6.5 hrs), but as I said, I've started to second guess myself. The main reason is because of the additional smoke that's been coming from the valve cover breathers on the new engine.
Here are the specific questions I have:
1) Is the smoke from the valve cover breathers normal during engine break-in as the rings seat to the cylinder walls, or is this primarily an indication of water entering the cylinders?
2) Do you think the method I used to test the manifolds is sufficient, or would you recommend a different procedure (or a trip to the shop with them)?
Thanks,
Don
Thanks,
Don
