Re: 90 Mercury 50 HP won't start
WD-40 used to be an excellent starter fluid, but not any more.
It used to use propane as a propellant and was labelled "Extremely Flammable". That worked very well as a starter. There may be some of that "NOS". If you can find it hoard it.
Several years back they switched the propellant to CO2 to make it "safer to use" and changed the label to merely "Flammable". I will still burn, but does not make a good starter anymore.
Well, no matter. You have proved that there is no spark, so getting spark is the next step.
I don't know enough about Mercs to give you good advice on the ignition system. If you have a factory Service Manual it probably has some trouble isolating procedures you can use.
Maybe a Merc-spert will come along soon.
Good luck.
