OttawaAquaBoy
- Joined
- Aug 15, 2005
- 29
Last spring I had purchased a rebuild. I had an older engine (pre-1998) that was used in salt water by the previous owner. The new one is (supposed to be) 2001- ish 3.0L (HO <-what I was told but I don't know if this is the case). I just want to make sure I have the proper manual for my motor.
I have no complaints about this engine, it is running like a top, I just need to know that if I do need to do some repairs or maintenance I have the right book for the right engine. It is definitely a different "model", the throttle attachements are located on the top rather than over on the manifold side.
I believe this is the s/n (stamped on the block around where the GM stamp and "made in Mexico") down by the starter.
14097080
Thanks in advance!
14097080
Thanks in advance!
