Re: 350 Chev OMC Loosing power at high RPMs - UPDATE
i am having a similar problem...have a mercruise 260 (gm350 5.7 on an '87 with alpha one outdrive.) i am using an auxillary 12 gallon tank brand new, new filter, new fuel pump, new 1409 edelbrock carb.
as soon as i hit 3000RPMs, the RPMs cut, and revs back to 3000, and cuts again. (sounds like someone reving a car and letting off the pedal every other second) as long as i hold the throttle at that level it will happen repeatedly, anything under that the engine runs fine. good compression, good water flow, even replaced my distributor and plugs about a month ago. everything is new and im giving up. any suggestions would be highly appreciated! btw this is not under load, this happens with muffs too.
