Re: 1986 Mercury 150 HP XR2, Bleed hoses.
Thanks John, I will probably see him tomorrow late morning or early afternoon. Engine is still running rough not firing on all cylinders until it eventually get on plane, then the motor kicks in all cylinders and runs fine for a short distant then starts missing again at various rpms. I have been through the fuel system now completely. I had old fuel (12 gallons) from last october, tried running the boat several other times earlier this year with these problems thinking it was sour fuel or water contamination, put in the correct measure start up additive with no success. I started the repair sequence from draining the fuel tank, removing from boat, flushing it out, removing all fuel and vent hoses, replacing any that required replacing, replacing vent tube. Pulled all three carbs, disassembled completely, cleaned, checked floats and float levels, replaced leaky reed block gasket, replaced fuel pump with new kit, all three carb gaskets, choke plate gasket, and new water pump kit. Test run on the river today and not much change, still bogging down and then slowly picks up enough speed to get on plane then other cylinders kicks in and will enventually start running rough again. I don't belive it is fuel related now. The Mercury mechanic made a comment to me to check the stator. He stated it probably is faulty when changing over from low rpms to high rpms. I'll get in to that tomorrow.
