Re: Engine overheating
I also noticed that I don't have water running from the exaust. I'm pretty sure that it used to. Probably blockage in the manifolds/risers?
I'd start by removing the hoses, and back-flushing each hose individually. Starting with the inlet hose, and moving forward in the system. Inlet hose on drive, then hose between heat exchanger and drive, then water pump to heat exchanger, then remove the thermostat housing, and flush engine, then exhaust manifolds. Finally, I'd remove the risers, and flush them separately. Then run a water hose down your exhaust Y-Pipe, and make sure you've got good flow. Once every piece is separately flushed, and has good flow, put it all back together.
You'll be able to identify areas with restrictions this way, and then you can start working on getting them cleared. Don't just flush one part and think that it's fixed. Check each area of the system separately, and make sure you get ALL the junk out of there, or it will end up plugging something else up later on. I'm thinking you've still got parts of a water pump impeller somewhere, or several "somewheres".
