exhaust question
bhale5
I have a 1971 merc 165 I6 that was converted to a trhrouh hull exhaust.I've never checked into this but I was wondering if there was some sort of muffler or noise dampener that can be installed that would quiet this thing down a bit.Thanks for any input.
Bryan
jerryjerry05
Re: exhaust question
Is the old exhaust tube still in the boat? It might be as simple as replacing the hose that was removed. Got a pic? Jerry
bhale5
Yes it still has the old exhaust tube. The previous owner installed a turbo to the engine and ran the exhaust straight through the hull. Is there any reason why I couldn't just hook up the old exhaust tube or is it necessary for the turbo exhaust to be run this way.Thanks
Maclin
I think the turbo needs the free-flowing exhaust after it to work as intended.
79Glastron
Hold the phone there! You a turbo charger on your 165? I'd love to see pics of that. I believe they make a marine muffler that would work.
bhale5
I'll take some pics and postthem.It might be tomorrow,but just watch out for this post. I thought it might need that free flow but wasn't sure.It sounds like a champ, but if Icould quiet it down that would be cool.Thanks
Really? I always thought you couldn't do that because of the heat.
79Glastron
I thought about this again, are you running water into the exhaust side of the turbo as well? I'm not sure how well that would work. I would think it would need cooling of some sort. I know large boats with turbo diesels must have a water jacketed turbo of some sort, right? Can't wait to see pics! Also, a muffler won't hurt turbo performance, or, not enough that you'll notice.
bhale5
Sorry it took so long to get back.Here are some pics of how its set up. Like I said this is how it was when I got the boat. All I know is it can really move on the water. I've never had a problem. At full speed it will go around 47mph on the gps. It will also yank up a 220lb skier with 5 adults in the boat with a 19p prop. No problem at all. Not sure who designed it, but it gets the job done. What's crazy is the engine is original, 37 years old.0709081828.jpg
Maclin
That looks almost factory to me! Looks like it has been installed and running for a few years now. Does not look like much room for a muffler though, I see why you were asking now.
bhale5
I don't have any idea. I don't even know what a stock 165 runs like so I don't have anything to compare it to.
starsnstripers
Well I'll be damned! Aint that something.:eek: What make boat? Length? I have a 21.5 with a 1970 L-6 and i'm sure it would struggle with 5 people and a 220lb skier. :D It does look factory with the carb way to the front of the eng. like that. If i could find one of those setups i might skip putting my 283 in the boat and save it for another project. Geesh Bhale, doesn't look like much room for a muffler. If you could elbow it over, down, and out, maybe. You;ll have to search the market and see whats available. good luck with that. Where ya from Bhale?
bhale5
Its a 17' 1971 Century Raven. I didnt realize how uncommon this was. Is there any way to determine how many hp I'm actually pushing. I'm down here in athens, ga.
starsnstripers
WOW, 17' ? that thing must rip! I'm not sure about how much hp the turbo adds to 165hp. I'd be guessing that your approaching 190-200 but don't go by me i dont know the formula for it. Maybe someone on here could be of more help with that. Did you check those exhausts out that Bubba sent you on that link? I think you may be able to plumb in a muffler system with one of those setups. Good luck with it. I'm in Me. so guess i won't be getting a look at it from here, but the pics were great. If i come accross any info on them i'll let ya know.;)
bhale5
Yes, I saw those mufflers. I have about 2' between the exhaust behind the turbo and the exit at the hull. Do these quiet things down substantially. It sounds like a hot rod but a little less noise would make cruising a little better.
MikDee
Banned
Yes, It's like going from a straight pipe (no muffler), to a glasspack mellow sound.
hard-3
How about a corvair turbo muffler? i would think it would have to be wrapped in heat resistive insulation of some sort. I've seen some industrial engines that have a ceramic coating then covered in kevlar to insulate it. Unless it is water cooled I would think a regular glasspack would get to hot .
Jeff
MikDee
Banned
Jeff
No, no, I'm talking about the Primax round silencers, as in the link provided by Bubba 135.
