Re: Prop to Crank HP rated engines?
How would one determine weather or not a particular hull has natural bow lift?
as my calculations went before, I was turning 5400 rpm's with a 17 pitch prop, at 33.6 mph, averged out in two directions.
The prop slip is 6.46 percent. To my understanding 8-10 is an ideal setup for a stepped hull bass boat, so I would think I am running very efficiently up top, but still horrible down low, not too sure how if at all that would relate to bow lift. I don't see me being able to add much efficiency up top, but possibly an increase in motor height and I may get some more rpm's, with less of the lower unit in the water to drag.
