force tile trim manual release?
Lefty 35
Force 120 Tilt Up stopped functioning. Lowered motor and now it wont go up. Think it is a solenoid problem but is there a manual release so I can lift the motor to trailer the boat? Any help would be great.
jerryjerry05
Re: force tile trim manual release?
There is a manual release.But I have found if you start messing with it it only leads to more trouble. Crack one or two hyd lines.Jerry
Frank Acampora
Most units I have seen do not have manual releases. I have only one (tilt only unit) which does have a manual release.
However: All power tilt and trim units have a set of check valves both within the tilt cylinder and within the pump. These valves hold the cylinders in position BUT---The release valves in the tilt cylinder allow it to kick up if you hit something hard. Because of this, if you yank really hard on the lower unit, it will eventually move. It's not easy, but it can be done.
Since the tilt has two solenoids and since either can fail and affect either direction, it is easier to simply replace both solenoids.
These are standard solenoids and cost about 17 bucks each in an electrical supply store. I have mentioned numerous times that these solenoids can be found in junkyards in Buicks, Fords, and Chevys. The only difference is that the auto solenoids do not have a mounting flange--small sacrifice for a visit to the junkyard. Pick upa half dozen to have extras on hand.
Every time I visit the junkyard, I get bulbs, fuses, and solenoids. Adds up!
Lefty 35
Thank you both for your information. I will try the cleave and jerk method first.
after posting I noticed that I have a circuit breaker mounted vertically on the motor frame that will not reset have I blown more than just a solenoid? Thanks again Lefty 35
