John Lapic
Thread starter- Joined
- Sep 8, 2007
- 57
I keep reading posts that suggest actual compression is not as important as the variation between cylinders. My 71 Johnson 9.5 measures 35 psi in both cylinders. This seems way low to me, but I don't know what it should measure. Anyone have the specs on this motor?
I did a decarb before I ran compression. Just to be sure I was getting accurate readings, I remeasured each cylinder three times with the same number of pulls on the starter rope. I can get no more compression. The compression gage came from my local automotive parts store as a loaner. I believe I am the first to use it. I can only assume it is rairly accurate.
