Re: 1992 Force 120hp dies in low RPMS
The short term fix is to advance the idle RPM screw to increase RPMs at idle. However, you should check the cylinder compression, carbs, and ignition system for proper operation. Also, fuel pump and fuel delivery system can be causing similar issues.
