procraft89
Thread starter- Joined
- Jul 8, 2008
- 11
We have an '89 ProCraft fish & ski that originally came with a 115 Mariner. When that motor blew, it was much more economical to buy a used boat and have the motor transplanted rather than buy a new motor. Now this boat has a '84 Mercury 115 I6.
From what we have been told, there was a change in the way hp was rated between the years, in '84 it was done at the flywheel and in '89 it was rated at the prop.
This motor is having some carb issues, trouble coming out of the hole without feathering the throttle but is ok once it gets on plane it seems to run good but isnt turning more than about 4200 rpm. Oddly enough when I first put it on the lake the other day I was able to get it up to about 5200. The lake was much calmer so it is possible I trimmed the motor out more to get the rpms. In addition, it will NOT push the boat on the trailer and fuel is obviously leaking out of at least 1 carb.....so they need rebuilt.
Since we are going to be into anyways we have decided this would be a good time to look at upping the power of the motor. Is it true that the block on this motor is the same as 125, 140, or higher? We have heard that with some basic changes we can effectively increase the hp.
Does anyone know what changes would need to be done? Is it just jetting or do we need new carbs? Does this motor have reed valves?
I am a pretty competent 2 stroke mechanic, my son races motocross so tearing into carbs and motors doesnt scare me at all as I do it all the time.
Thank you very much in advance.
Ed.
Ed.
