I have a 50hp 1985 force. When i first got the motor i had to change the solenoid and then it started up fine. However, one weekend i went out to use the boat and the motor would not start. It was a basic turn the key nothing happened, so i did exactly what i shouldnt have done and started throwing parts at it lets see i replaced the starter, starter solenoid, rectifier, neutral safety switch, ignition switch, and all electrical ends. Of course this did nothing to help the motor. So today got the brilliant idea to use an electrical tester on the thing and found i had power everwhere in the motor except on the outgoing to the starter from the solenoid. Good 12 volts on one end nothing on the other. This is with the key turned on and in the off position. I also found i had 12 volts on yellow wire connected to solenoid while the key was turned, im assuming this is my ignition wire. just wont send power to the starter. any help or questions would be greatly appreciated. thankyou
