bigpoppakdog
- Joined
- Jul 9, 2008
- 437
Heres the story. Bought this boat with the understanding that the previous owner had reversed battery terminal wires.
1. Took it out, ran ok except surged at high speed.
2. Thought that was fuel, changed all fuel components(cleaned carbs)
3. Boat ran fine again, except at high speed.
4. Boat suddenly lost spark.
5. Replaced starter selenoid, stator.
6. Boat ran again, except high speed
7. Bought new retainers(red) so I could adjust slow idle screws.
8. Boat suddenly had no spark(all cyclinders)
9. Replaced pulse pack. Still no spark.
10. Rectifier tested as dead. Bypassed ignition safety circuit.
(lost spark regained spark now 4 times. This motor at 3/4 throttle still flew and had awesome hole shot. Just made a major "hiccup" at full throttle attempt). This has never died on me while using it. Get home, park it, go out the following day and won't start.
Any thoughts. I'm going insane, it seems like this thing "jars" something loose and causes spark to quit. I didn't change ignition coil. Spark plugs are new and correct for engine. Ignition shows power to terminals where it's suppose to. Seems to me the only things thats left is changing ignition coil, starter safety switch performs properly as it will shut down ignition when I throttle it up. The stator-rectifier are for charging the battery for this motor correct? Thus not related to ignition??? Sensor, distributor, pulse pack, ignition coil, ignition switch are the ignition components right? The ignition coil does not create a spark when I have lead pulled off coil and stick a screwdriver in end. That's about it without writing a book. HELP!!!
