Re: 75HP Chrysler overheating
While the 12 vane impellers are still available, the six vane are actually more efficient at low speed because the lower number of vanes allows more open area to suck in and "compress" the water. The extra vanes take up area that water could be in. So, the six vane should not be a problem.
Check the inlet screen on the lower unit. It may have some solidified gunk on it restricting water flow.
Also be absolutely certain that the brass delivery tube is sitting inside either the black rubber grommet on the water pump or the white plastic sleeve. (depending upon which water pump you have). If either is missing , most of the water will just blow out into the lower unit and not make it up into the block.
Since you reference a 12 vane impeller, I am assuming you have an older two piece lower unit with a 3/4 inch thick impeller. As far as I know, no one piece lowers with 1 inch thick impellers ever came with a 12 vane impeller. SO:
The impeller is located on the shaft with a rather small woodruff key. It is quite common for this key to slip out of position during installation. If this happens, the impeller will simply spin on the drive shaft and pump no water. Yet, with a hose, you will be able to get water to the top of the engine.
If you listen carefully, when you drop the lower unit, if you turn the shaft clockwise by hand before you remove the pump, you should be able to feel and hear the impeller turning.
The correct way to install the impeller is the locate the woodruff key in the shaft slot and slide the groove in the impeller over it. THEN, lower the water pump with a counter-clockwise twisting motion over the impeller. Lubricate the impeller beforehand with dish detergent.
Oh, yes! if you take apart the pump, be sure that the bottom stainless plate and the gasket are present and are in good condition
