wildmaninal
Thread starter- Joined
- Jul 14, 2007
- 1,897
If my rpm gauge is reading correctly I'm only running at 4500 rpm at WOT when I know I should be running about 5000 to 5500.
I have this 1978 85hp on a 15ft tri hull bass boat. I haven't done anything with the prop, I believe it is the original. Been trying to read up on the service manual but I really only see about synchronizing on the carbs. Which I believe the carbs are in sync but I have noticed that it is running a little to low on idle which it has been known to die at idle, haven't paid attention to the rpm at idle though :redface:. It also takes a moment for the boat to get on plane.
I just want to make sure I am going on the right track. Should I just adjust the throttle trunnion nut? Will I gain that extra 1000 RPMs by doing so or no? What rpm should I be at at idle?
I have been using my boat like this and I actually can keep up with my brother's 1975 115 hp on a 75model 17ft bass boat hull. I believe my rpm gauge is accurate though for real. I also have the old style 2 handle remote hooked to this motor this might have something to do with it I don't know.
