Hi, I have been exploring this forum for a week or two now and just now decided to join and throw my question out there. I have a '69 Boston Whaler 13 Sport with a 95 40hp Johnson on it. It was my aunt's and it sat for a few years before she gave it to me. I am a car mechanic so I know how to get my hands dirty and figure things out but I really don't want to mess up this motor on things im not sure about.
On to the problem. While the boat is running it will idle fine untill put into gear then up till about 1/2 throttle it will run fine. When I try to get on plane and stay there it will run for about 5 sec. then bog out. When I first started working on the boat I cleaned the carbs the same way I would on a car and put them back on. The VRO system was also bad when I first got it so I saw on this forum that I could replace the pump with a non VRO pump which I did but it was a used pump. So what my plans are is to order a brand new fuel pump and I would like to know which one I should be buying for this motor. Also I want to order carb rebuild kits and have both carbs rebuilt by a professional boat mechanic. A link to carb kits and fuel pump needed would be great. Also I don't want to go back to a VRO setup as I figure if I have to carry spare oil around with me incase it fails I should just mix my own.
Thanks a bunch in advance for any answers given. Sorry for such a long post.
