compression
cavy
Hello
I have a 1993 mariner mag 3 150 hp. I decided to to a compression test.
I took all the spark plugs out and measured each cylinder. i got between 70 and 72 on all six cylinders. What should it be? Does this seem low?
Jim Cav
Barnacle_Bill
Re: compression
That is low. How many times did you let the motor turn over when getting a reading? I usually let them turn over until the gauge stops rising.
Steven1962
Re: compression
It does not matter what your numbers are, what matters is that they are all close to the same. not more that 15 psi differance between them. All gauges very, all people do things a little different. If they are all that close you are good.
cavy
Re: compression
will the lower compression limit power?
JB
Re: compression
Lower compression "readings" do not mean lower compression, cavy. They are simply readings. That is what Steven is saying.
The purpose of compression checks on 2 strokes is diagnostic. . .is there a bad cylinder or two? In your case the answer is no, there is not even one bad cylinder.
Re: compression
The low numbers as others have said can be misleading. Dont forget when the engine reaches its running temp to pressures will go up. Sounds like you dont have a problem.
bchoate
Re: compression
Sounds like you have a bad guage. The compression reading on that engine should be about 115 to 125. But as long as all are within 10 to 15 percent as noted in previous posts it sounds normal. Try a different guage.
