I bought a boat from a guy, and it has a 1978? johnson seahorse 70hp engine. The motor started up and ran fine. He even showed me that is has exactly 130psi in all 3 cylinders. Well I get it out on the water to find out that reverse makes the boat go forward, and forward makes it go into reverse! Also when I put it into reverse to go forward, even with the throttle all the way down it only revs to around 2000rpm and goes about 5mph. Im assuming this has something to do with the cables being reversed correct? How do i fix this?
