115 yamaha outboard
lanrover1
took out yesterday-had hard time starting but it did start. ran great. took today (sunday) wouldn't start. can someone help.
thanks
lanrover1
matt2002
Re: 115 yamaha outboard
What year ? Did you check your fuel filters ?
They like alot of choke,if yours has the choke that you can pull out on the engine try it .Your push in choke may need to be adjusted.
Bodean2
I have a 2002 115hp and had the same problem. If you choke by pushing the key in, check to see if your solenoid that actuates the choke is adjusted properly. Take the cover off of your engine. The solenoid is located, as you look a the front of your engine, on the front left of your engined above the carburator. It is attached with 2 bolts. Loosen those bolts and slide the solenoid up (it is adjustable). then tighten. this will tighten the choke linkage. if the choke does not close all the way, it will have a hard time starting when cold. this takes 5 minutes. It fixed my starting problems. Please try this before anything else. It works!
