Re: 1962 qd-23 10hp
So, when you say that your QD is "still running," do you mean that it's running well or running poorly. If it's running well, both at idle and at wide open throttle, then you're not leaking that much fuel for that engine. Check your fuel lines, to make sure they're not leaking anywhere, but if it's running properly, that's what they do.
On the other hand, if it's running poorly, especially at idle, and if it's chugging and the like at other throttle openings, then it's time to clean your carburetor and put a new carb kit in it. Those oldsters had cork floats, and they get heavy and can cause an over-rich fuel mixture, causing excess fuel to spill and the engine to run poorly.
So, how's the old girl running, exactly?
