fishinhardwater
- Joined
- Jul 13, 2008
- 47
My 1988 mariner 3 cylinder 60 HP engine's overheat alarm goes off on the throttle control box. This beeping occurs at Wide Open Throttle only. The dealer sugggested new impeller, did that, problem still occurs at WOT. Tell tale is strong at all speeds. When i drop the throttle back to slow or neutral beeping stops, and engine stays cool entire time even when its beeping. By the way its a continuious beeeeep, not a beep beep beep, which would be for low oil. I can also run engine at 1/2 and 3/4 throttle all day and beep does not occur. thank you
