Nandy
- Joined
- Apr 10, 2004
- 2,145
On Saturday the gas gauge for the Blazer dies. It just went past the E mark as when you turn off the vehicle. I check the fuses and there is a gauge fuse but is for all of the gauges and it tested ok. I could not find any other fuse associated with the gas gauge. The sender is built in the pump which I changed maybe 2 years ago, maybe more. It was over $200 if I recall right so I am not crazy about changing it again. I looked for the old pump as I thought I kept it but I cant find it now. Anyway, the problem could be somewhere else.
Does anyone know which pins I need to short at the pump connector to test away from the sender to see if the needle goes up? I hate to take the gas tank down and the pump out just to be able to trace the cables. The book I bought was a Chilton CD and I have to say that I will never buy one of their cd's again.
