I have an 89 mercruiser alpha 1 with 4.3 litre mercarb gm engine and everything is fine until it gets warm then I have to run it at idle all the way home because it wont get up on a plane without stalling or bogging down. Fuel filters are clean.
ordered a rebuild kit for carb, strange thing it usually doesn't stall just cuts out until i reduce to idle then idles fine and will speed up smoothly for a couple seconds then feels like i run out of gas so back to idle all the way home.
Dealer said might also be ignition amplifier or sensor in dist. I removed dist cap and seen a little build up on the posts inside how can the rotor be removed? it seems stuck on and when I pry on the 6 metal legs they want to bend. wouldn't it not start if it was a bad ignition.
