Chech this out about PL adhesive!!
redfury
Re: Check this out about PL adhesive!!
Interesting read. Sure makes you wonder what would be the better choice for using as a bedding compound for stringers. You can "fair" out the crack sealer easier, but it's not as ( supposedly ) strong as the regular PL adhesive but the adhesive bubbles if you try to work it smooth...
Definitely worth considering.
drewmitch44
Re: Chech this out about PL adhesive!!
I did a test with the other PL Concrete version. Its not at strong! I am going to use the Pl Poly const. adhesive. It says Premimum on it but it is not called "PL Premium". Its Just PL construction adhesive. It buggs me when i hear someone call it "PL Premium". It makes me think there is some other PL that im not aware of. I Bed stringers in with the PL Construction Adhesive. Been doing it a long time and its been good so far. This sea ray that im working on, (my boat, hence why its taking so long) i just used 4 of the big tubes for each stringer. The 28oz tubes...... http://www.stickwithpl.com/Products.aspx?ID=fef65cc9-47bf-4802-aaa9-a343f2ef9458
Ezrider_92356
i bedded my stringers in PL premium construction adhesive probably going to use it to bed my floor as well when i get that far. i am hoping to get the stringers and transom glassed in tomorrow the floor in the next couple days. seemed to work great for the stringers its not fully cured yet though.
