Just got a 93 Tracker with a Johnson 40, hadn't run in over a year. Cleared complete fuel system and replaced with fresh, plugs are fine. Fired up and ran about 8 miles upriver beautifully until I started hearing warning horns (don't know what they were, didn't count). Cycled the key, horns went out. The temp of the motor was fine, it has plenty of water pressure, if anythihng the head feelt cooler than I would have expected. Anyway, about a mile and a half back the motor starts losing power and just dies. No horns. Wait a few secs and fire it up and go again. This goes on and on every 1/4 to half mile till I finally run the battery down and it won't crank fast enough anymore. My fears are/were lack of oil and that I finally scored the pistons. When I got home, I could easily turn the motor by hand and obviously felt TDC on the compression stroke, so my fears were lessened a bit (I did not try this on the water, wish I would have!) I put the battery on charge and went and bought a Clymer, the only book I can find locally. I have a few questions: first what would this appear to be a symptom of? Second, what should the compression on each cylinder be, I have not found it in the book yet. Any help would be greatly appreciated . . .
