littlebookworm
Thread starter- Joined
- Nov 30, 2007
- 574
Hi, everyone. I'm finally just about ready to drop in my new-used engine into my boat. Engine is a 1983 Mercruier 5.0 with raw water cooling. Had to do a valve cleanup and lapping, but everything else was fine. I'm running it on a dolley at the moment with water hose connected. At idle, oil pressure is 30 lb. At 3000 RPM it goes up to 60-70 lb. I've checked with a mechanical guage and got the same readings. I've dropped the pan and the oil pump and checked the pressure relief valve. OK. I've changed the oil filter even though it was new. Oil is 30 weight. The engine does have a no-name aftermarket remote oil filter setup using a PH8A filter rather than a PH30 filter usually listed for that engine. The 8A does have a smaller mounting/flow surface than the 30. Could that be causing the high pressure? Is it something I should be concerned with? Thanks. Hy
