forexsystemresearch
- Joined
- Jul 15, 2008
- 17
First off, thanks to everyone for all the help so far with my first boat. You guys are great!!!
I have a 1989 force 125 that I just bought and have been fixing up and trying to get it running cherry.
I have changed plugs.
I decarbed tonight with seafoam spray( seems to run better and smoother)
I have synced the carbs so both butterflys are open at wide open throttle.
Overall it seems to run pretty nice, smooth at idle, very fast wide open.
My problem is that after syncing the carbs, the idle was too low and I had to turn the idle all the way in in order to get it to idle fast enough so it wouldnt die if I shift into gear. I even had to remove the retainer nut in order to screw the idle in further.
Any suggestions??? I must have another problem that is causing this.
Many thanks in advance,
Mike
Mike
