how to rebuild
pistolp
how do you rebuild a feul pump on a 73 chrysler 130 outboard and where could i find the parts and please look in my public pro to see the pic of my boat and tell me how fast should it go and how do i reconnect a speedometer thanks for any tips and what is decarbing and shopuld i do that after rebuilding the fuel pump if so how sorry fairly new to owing a boat
eurolarva
Re: how to rebuild
Start with a sierra kit 18-7806. This can be had from a NAPA or here at Iboats. Just replace the diaphram and the gasket. There are three small gaskets in the kit that are suppose to be for the check valves in the pump and each kit I have gotten they were too big to use. When you have the pump apart visually inspect each of the check valves and verify they work and you dont see problems with them. The pump is easy to do. Just remove from boat remove six screws take old diaphram out and put in new and gasket and reverse procedure. Cant help with the speedometer but for cheap you can get a GPS that will give you more accurate info then a speedo.
Decarb is using a solvent with gasoline to help remove the carbon deposits in your motor. The procedures for doing this are outlined in the FAQ forums here at Iboats. Click HERE for going directly to Decarb a motor.
