Hi this motor was running good now all of a sudden, it does start all be it hard, then only at a high idle. Replaced the plugs and good compression in all cylinders. It does have a distributor cap. Do these normally cause problems??
When it is running you can here it missing and every once and a while the other cylinders catch and all is good but that is becoming less often
Ideas
Help
Ideas
Help
