1st boat, looking to add some basic features
Kassun
I will be picking up my 1st boat in a few weeks. It's a basic 14ft Northwoods made in the late 80's early 90's for $650 w/trailer. I am going to put on a 9.9 or 15 hp motor on the back.
The first item i want to add in is a floor. I have read many posts, but most of the work I have seen have been for fiberglass boats. For the space that is open between the boat and the top of the floor, do I shim with 2x4's or do I use 2x4's and a combination of foam?
Thanks for your time,
Kassun
jonesg
Re: 1st boat, looking to add some basic features
Welcome,
do some reading, theres lots of info, PT ply is the wood of choice for stingers and floor support.
If the floor is gone, how is the transom?
Its easier to fix a wet one now than have to cut that new floor out later to get at it.
Cheers, Gerard.
i disagree on the Pressure Treated plywood. especially in an aluminum boat. metal does not like the pressure treating chemicals.
post some pictures of your situation.
Kassun
Here are a few Pictures of the boat.
Thanks,
Kassun
what i have found that works very well with those boats. are panels between each seat, they are removable for cleaning, and no fastening. cut 5/8 exterior plywood to fit area, then ad striping to the bottom of the plywood,to fit the contour of the hull, this gives an flat area to stand. feet dry. if it will fit fuel tank under middle seat. no need for foam.
Shizzy
Ensign
Im going to do as TD said between the seats of my 14' Aluma craft. I did however put a platform over the two front seats. I carpeted it, hinged it and added a lock so now that front area is a nice casting deck and I have a large lockable area under to store gear.
Kassun
doesn't a casting deck mess with the center of gravity? How did u secure the casting deck between the seat and the bow? I wouldn't mind doing it just for the storage aspect of it.
Thanks,
Kassun
Kassun
Well I got her home and will start the washing out in a day or so. I have read some posts where persons have removed the middle seat and put in a flat floor to make room for live wells, rod holders ect.. Can any one offer advice that have done what I am contemplating? Also I would imagine that I would have to weld in a brace to support the area where the aluminum seat was removed like a U shape that hugs the hull?
thanks,
Kassun
Kassun
here are the updates, started and finished her today. Gona test her out Sunday morning.
-kassun
SnappingTurtle
-kassun
It turned out really nice.
Not bad (caution understatement) for a days work I would say. :cool:
tmcalavy
Ditto, nice work. Enjoy it on the water.
Kassun
Thanks guys, I took her out on Sunday and was very happy with the layout. It was nice to stand on flat carpeted floors instead of a hot hull. I am still looking at adding in a live well, bilge pump ect.. to finish it off and of course an outboard motor:).
Thanks,
Kassun
Shizzy
Ensign
much better job then I did. mine is just one large piece hinged in the front. Ill probably redo mine over the winter more like what you did.
BIGcarpy50
remember what the boat is rated for.....a small narrow boat like that might not do to well with a full livewell of water. Also i would be carefull removing the middle seat. it is there for structure. i mean the boat won't colapse but over time the alum might get stressed in spots...other wise nice job.....if you like doing work you might be able to find a bigger boat that needs some work. check out my post and my project.
http://forums.iboats.com/showthread.php?t=270495
Kassun
BIGcarpy50: I agree with the middle seat. I decided to keep in rather than go the route of taking it out and having to worry if I braced everything correctly. I did some different layouts, and have decided to do 2 storage boxes on the sides between the rear 1st and 2nd bunk. They will come out approx 6" and inside they will hold some tackle. I'll probably frame them with a 1x2 ripped in half, and sheeted with 1/4" ply. This way I can save on weight, and they won't have to be heavy duty because they will just hold several plastic boxes.
I was considering the live well/bait well, but like you had mentioned, I'll do that when I upgrade to a 16' deep V in a few years. I think I'll buy one of the portable bait buckets from Cabela's that are insulated and come with the air pump for now.
There is a guy locally that has a 16' fiberglass boat that looks pretty rough but has a ton of potential for free, but unfortunately the weight is an issue and would probably pull my Toyota Matrix into the water along with the boat on some of the steep boat launches we have up here :). http://duluth.craigslist.org/boa/801868467.html
thanks for the feed back,
Kassun
BIGcarpy50
thats not a bad boat...but if your looking to fish i would wait for an aluminum one to pop up with an open bow....better for weight, less up keep, and you can bump into the rocks without freaking out..........but in the meantime hold onto the one you have......good luck
