fluidjuice
Thread starter- Joined
- Jun 12, 2008
- 54
Hi
i have a 40 hp classic mercury 1991 4 cylinder ,
It idles fine on top two but when you put in gear and give it some revs it stalls every time, this is done in the habour so it has enough back pressure.
The bottom two cylinders dont seem to be running at all so i took it to have carbs stripped down and cleaned thinking it was a stuck jet.
the carbs have been cleaned, and the engineer said that the compression on all 4 was good, and was sparking on all 4 cylinders ,but the bottom two cylinders dont run, so it must be fuel related ???
But for him to strip engine to trace problem at ?40 per hour was going to be a huge bill and not worth the effort???
I have read many trheads on iboats but none have any conclusions to point me in the right direction, any info would be truely helpfull.
