Re: instrument guages dont work 2002 Bayliner
Silvertip hit the nail on the head. Before you start throwing dollars out, start checking. You'll need a test meter or test light. Hook the negative side of the test meter or lamp to a known ground. With the key on, check for voltage at the guage panel. Use the generic wiring diagram at this forum for a starting point. Find the guage to which the power first arrives. All the other guages are pig-tailed to it. If there's no power, the break is before them. If there is power, the break is in your ground circuit. Look and you will find. Good luck. Hy
