I have a 1989 Suzuki DT30C. Propeller shaft housing somehow got violently displaced, twisting house and cracking upper threaded screw hole in lower unit casing and causing lower screw to twist off on removal. Question is: How much pressure/torque is applied to this unit. I believe that the lower screw can be removed and re-threaded, but am unsure of condition of upper screw. Probably can remove distortion but cracking around threaded screw hole will still exist.
Looking for suggested repair options or source for new housing.
