Nandy
- Joined
- Apr 10, 2004
- 2,145
I have change bearings before in cars but this is the first one for trailers. Well, I changed one side yesterday first but not too familiar with the bushing set up I found out today that I broke the seal by pining it with the bushing. I was installing the spindle nut washer that was not there when I took the old bearing set. I will have to replace that seal this weekend. I replaced the other side today before going to work. I put it back and took the boat for the ride. Once I made it to work the hub was very hot to the touch. I never felt bearings that hot. However... I installed 2 new Red Eye Bearing Buddy. The cotter pin from the spindle nut dug a "trench" in the inside of the bearing buddy.
My issue now is what is causing the heat situation, either is the cotter pin friction on the bearing buddy or the bearings itself....
In your experience, excluding the bearing buddies and missing grease, what else can cause extreme heat in the bearings?
I will post the Red Eye/cotter pin issue in a separate post as I think it is a separate issue on itself..
Thanks!
Thanks!
