Here's the story,
I have a 1958 Johnson 35 H.P. Super Seahorse model # RDS-20
I have rebuilt the carb step by step with the original repair manual.
Here's the Problem,
Very hard to start, I have to pull the choke turn it over, push in the choke continue to crank it while feathering the throttle, then it will start, If It dies repeat this procedure, with each time taking longer to fire up.
Once running it runs great 1/4 1/2 and full throttle, but when I take it down to Idle, it stall's, and I have to go through the whole start up procedure again if it is been running for a while it could take up to 30 min before it fires?
I guess my major problems is at lower throttle speeds Any help / advice . Or should I just take it to the repair guys who wants 200.00 just to look at it?
If I didnt own JUNK what would I have?
Here's the Problem,
